No "voice" on inbound calls, UC560
Feb 11th, 2010
Hello, I am having an issue with calls inbound to my UC 560.
The SIP provider suggests is may be a NAT setting.
They also suggest to "suppress" the first set (c=IN) in the code (below) since it is asking for a private IP:
o=CiscoSystemsSIP-GW-UserAgent 5653 7153 IN IP4
s=SIP Call
i=(o=IN IP4
c=IN IP4
t=0 0
m=audio 54472 RTP/AVP 0 101
c=IN IP4
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
Please advise.  Thank you.
John Platts Thu, 02/11/2010 - 12:39
According to RFC 2327, the c=IN IP4 takes precedence over the c=IN IP4 line because the c=IN IP4 line is the media level address and the c=IN IP4 is the session level address. In addition, SIP servers should not be embedding private IP addresses that are not reachable from the UC560 in their SDP descriptors. SIP ALGs actually take care of this problem by ensuring that only public IP addresses appear in standard SIP headers and SDP descriptors. SIP ALGs also rewrite the ports used for media streams, open up the correct ports on the router, and forward the media streams to the correct endpoint.
The problem you are having appears to be an IOS bug, but it is also being incorrectly handled by your SIP provider, as SDP descriptors should not contain private IP addresses that are unreachable from the other endpoint.
Maulik Shah Thu, 02/11/2010 - 14:13
John is correct - what is the NAT device in front of the UC560 that is doing the NAT ALG. There is no issue on the UC560 per se - the ways to resolve this:
1. NAT ALG device should translate both c= lines (session level and media level) instead of only media level. Depending on the NAT box this may or may not be doable
2. Service Provider SIP proxy adheres to RFC3264 and only looks at media level c= line and ignores session level c= line
3. A hack is to remove the session level line in UC560 as below:
voice class sip-profiles 1
request ANY sdp-header Connection-Info remove
response ANY sdp-header Connection-Info remove
voice service voip
  sip-profiles 1
See if those help.
Related Content
