CW: Report Export
Feb 11th, 2010
I'm trying to export a "Campus User Tracking" report to a CSV file, after getting the "Exporting Report" window and clicking "OK"
I get a beep and the window disappears. Can't find an exported CSV file anywhere. Is there a export report configuration parameter
that I'm missing? The "PDF" export works and sends a file to my monitor.
Joe Clarke Fri, 02/12/2010 - 09:05
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What version of Campus Manager?  There were some export bugs in earlier versions, but everything should be working in Campus 5.2.  Additionally, make sure your MIME types are properly setup in your browser.  The CSV file type may be associated to a bogus application.  You might try using Firefox or test a different client to rule out a server issue.
Rick Meier Mon, 02/15/2010 - 05:15
Campus Manager 5.0.5
Works on other clients
Installed FireFox on my PC, it works
Upgraded to IE 8 on my PC, still doesn't work
Michel Hegeraat Mon, 02/15/2010 - 06:25
  • Gold, 750 points or more
I think for IE you need to configure things in the browser to permit file download and stuff.
If you use a supported browser you get a link on the page where you type your username password.
This link also contains info on how to configure the browsers
Cheers,
Michel
