802.11a/n; High latency when Channel Bonding is turned on
Feb 11th, 2010
AP Type       LWAPP
AP Model     AIR-LAP1252AG-A-K9
IOS Version     12.4(21a)JA2
Radio Detail :  802.11b/g/n  AIR-ANT2422DG-R
Radio Detail :  802.11a/n    AIR-ANT5140V-R
Atheros AR5009 802.11a/g/n
AP - WPA2 AES eap-fast 5.0GHz/54Mb Bonded Channels
Client - WPA2 AES eap-fast 5.0GHz/54Mb Bonded Channels
Getting High Latency when Bonding Channels as well as packet loss.
When unbonding the channels the Latency and Packet loss is minimal.
Ping times: Bonded Channels
Minimum 1ms / Maximum 2765ms / Average 189ms
Packets lost out of 1000 = 509
Ping Times: Unbonded Channels
Minimum 1ms / Maximum 115ms / Average 3ms
Packet's lost out of 1000 = 3
Why do we care? I want to use Bonded Channels to increase throughput.
These Clients are viewing large image files and they need to load quickly.
Thanks for your assistance!
Leo Laohoo Thu, 02/11/2010 - 13:30
From the main page, if you click on "Clients" and the client's MAC address, what is the Signal Strength and the Noise level?
Michael Garcia Thu, 02/11/2010 - 15:29
is this what you're asking for? Also the AP is located within 30 feet away at the most.
Client RSSI is -81dB
Client SNR is 17
i've opened a TAC case. I'm about to deploy 140 devices and I need this working
ASAP. So in the interest of time... I'll post the results of our disgnostics with TAC once this
is complete. Thanks gang!
Leo Laohoo Thu, 02/11/2010 - 15:48
You got this right Michael and the result is not good.  -81dBm Signal Strength and 17 SNR is not a good sign.  It sounds like the client is too far away from the AP or there could be obstacles blocking between the AP and the client.  A good Signal Strength is -65 dBm or lower is better and 25 dBm or higher is better for the SNR.  I could be wrong.
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
