Source ping from Inside interface asa
lkadlik
I know there is a way to source a ping from the internal interface of an ASA or Pix firewall but cannot remember the commands.  Any help would be appreciated.
Thank you.
Ganesh Hariharan
Thank you.
Enter the following command for extended ping from firewallas source interface and define the destination ip and following parameters in extended ping command.
Firewall# ping
Interface: DMZ
Target IP address:
Repeat count: [5]
Datagram size: [100]
Timeout in seconds: [2]
Extended commands [n]: y
Verbose? [no]:
Validate reply data? [no]:
Data pattern [0xabcd]:
Sweep range of sizes [n]:
Hope to help
If helpful do rate the post
Ganesh.H
That was the answer. Thanks.
