BGP - default route origination from secondary site
Feb 11th, 2010
I would like someone smarter than me to look at this config and let me know if it will work. In the example, Memphis is the home office, and when up and working, the Memphis WAN router originates the default route to the MPLS network:
int s2/0.100 point-to-point
ip addr 152.177.98.78 255.255.255.252
router bgp 845
neighbor 152.177.93.77 remote-as 65000
neighbor 152.177.93.77 default-originate
The secondary site, New York, must be able to accept the default origination when Memphis is up, but then NY must originate the default route if/when Memphis goes down. I have that configured as follows:
ip addr 152.177.156.90
router bgp 845
neighbor 152.177.156.89 remote-as 65000
neighbor 152.177.156.89 default-originate route-map DEFROUTE
route-map DEFROUTE deny 10
match ip address 1
access-list 1 permit 152.177.93.78
I have also considered that the route-map and access-list could be reversed and still work, but I'm not sure:
route-map DEFROUTE permit 10
match ip address 1
access-list 1 deny 152.177.93.78
Any help would be greatly appreciated. Thanks.
Giuseppe Larosa Thu, 02/11/2010 - 22:43
  • Hall of Fame,
    Founding Member
Hello Billy,
what you have done up to now is interesting but it doesn't work. You are trying to match a prefix but in the ACL you then try to match a BGP next-hop.
to match a BGP next-hop in a route map we should use a different match statement:
match ip next-hop acl#
but your NY router sees a different BGP next-hop the one provided by PE router (if this is an MPLS L3 VPN service).
There is an interesting feature for cases like yours called BGP conditional advertising.
see
http://www.cisco.com/en/US/docs/ios/12_1/iproute/configuration/guide/1cdbgp.html#wp1023342
neighbor ip-address advertise-map map1 non-exist-map map2
this implements the logic that you would like to use. Route-maps are used to provide what to advertise when some prefix disappears.
I'm not sure it can be used if you only receive the default route on the eBGP session.
see also
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a0080094309.shtml
Another possibility would be to provide to default route received from Memphis an higher weight then locally generated prefixes for example using
neighbor 152.177.156.89 weight 40000
the NY router would choice as best a default route received on the session and it will not advertise its own until the other one is alive.
This should be the simplest way to implement this.
neigh 152.177.156.89 weight 40000
neigh 152.177.156.89 default-originate
Hope to help
Giuseppe
Related Content
