02-11-2010 04:59 PM - edited 03-19-2019 12:27 AM
Hi there, I am having an issue tracking down the COP files for CUCM 6.1(3) to enable Cisco Services Framework device type. Can someone point me in the right direction.
Thanks in advance!
Brendan
02-11-2010 05:24 PM
02-11-2010 05:27 PM
The readme file:
http://www.cisco.com/web/software/282764070/28984/CUCIMOC7.1.3README.txt
The download files are located under software downloads "Voice and Unified Communications". Go to Unified Communications Applications>Unified Communications Clients
You will see "Cisco UC integration for ...". As you drill into one of these and pick a version. You will see that you can download a .zip file. In the .zip file is the COP file you are looking for.
Bill
