On the ACE how do I change http://abc.apps to go to http://abc.apps/abc
Feb 11th, 2010
I am load balancing the servers ok , at the moment in test environmnet
so client types in http://abc.apps/def  and that goes to the real servers  eg http://realserver/def
what our customer would like is just to go to http://abc.apps  to go to the same location http://realserver/def
how do I do this in the ACE configuration
venkatkr Mon, 02/15/2010 - 21:39
You need to be careful that you dont get into a loop.
when the client enter http://abc.apps then it would resolve to an ip. Lets say is the VIP.
ACE gets a match, then you need to perform layer 7 load balancing. If there is no abc, then do a redirect
Created redirect rserver
   rserver redirect abc_redirect
     webhost-redirection http://abc.apps/abc
server for redirect rserver
  serverfarm redirect URL_REDIRECT
  call the rserver
layer 7 match
  class-map type http loadbalance match-any matchurl_abc
    2 match http url /abc
Policy map should look something like this
policy-map type loadbalance http first-match ABC
           class matchurl_abc
             serverfarm x
           class class-default
            serverfarm URL_REDIRECT
Hope this helps
