STM-1 OC3
Answered Question
Feb 11th, 2010
Hi all,
Can we get 2 port fix STM-1 OC3 interface module (port adapter) for 7200 VXR or do we have to buy separate SPF for it ??
Help will be appreciated.
regards,
Uttam
Correct Answer by Giuseppe Larosa about 7 years 1 week ago
Hello Uttam,
current 2 POS PA uses external SFPs
see
http://www.cisco.com/en/US/prod/collateral/routers/ps341/product_data_sheet09186a0080145f66.html
the same happens for 1 port PA current version.
http://www.cisco.com/en/US/prod/collateral/routers/ps341/product_data_sheet0900aecd80221d3d.html
I agree that older PA had built-in optics I remember to have used them
see end of life notice
http://www.cisco.com/en/US/prod/collateral/routers/ps341/prod_end-of-life_notice0900aecd802f91fd.html
note: it is clearly stated that you need to order SFP separately no default bundle exists.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Fri, 02/12/2010 - 00:25
Hello Uttam,
see
Hope to help
Giuseppe
urs.shrestharana Fri, 02/12/2010 - 01:35
Dear Giuseppe,
Thanks for your help. Yes, VXR 7200 supports 2-Port OC-3/STM-1 Packet-over-Sonet port Adapter and SFP is separate and that you have mention the 1port STM-1 EOL. Thanks for you kind help.
Uttam
