Source based SSH
Feb 12th, 2010
Hi, I have 6506 switch having 10 L3 vlans. I want to ssh on any router from this 6509 switch. My requirement is, I want to use different differnet vlan for SSH as a source. I m getting the feature in telnet like telnet x.x.x.x /source-interface. But I am not getting any option in SSH.
Please help how can I do it?
Overall Rating: 5 (3 ratings)
Ganesh Hariharan Fri, 02/12/2010 - 23:48
Hi Rupesh,
for ssh support also you should have crypto ios image in your switches, configure the following command in switches ip ssh source-interface " interface or vlan "
If helpful do rate the post
Ganesh.H
Ivan Krimmel Sun, 09/25/2011 - 05:38
AFAIK, there's no command to manipulate the source of SCP copies, so it will be based on the RIB lookups, i.e. the best outgoing interface in accordance with 'sh ip route will be chosen as the outgoing interface.
HTH,
Ivan.
