wireless Lan controller not access by GUI interface
Feb 12th, 2010
Hi All,
         i have one new cisco WLC 2106.i am not able access it by GUI interface.please help me how can i access it.It is true i am totally new for cisco wlc.
Leo Laohoo Fri, 02/12/2010 - 00:53
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
If you are new you can start by reading this ...
Cisco Wireless LAN Controller Configuration Guide, Release 6.0
http://www.cisco.com/en/US/docs/wireless/controller/6.0/configuration/guide/Controller60CG.html
Arup Dutta Fri, 02/12/2010 - 01:00
Hi Leo,
thank you for your quick reply but i had done each and every thing and
after that i am not able to access it.already i had configure like that
which is mention below.
(Cisco Controller) >show interface detailed management
Interface Name................................... management
MAC Address...................................... 00:1b:d5:cf:c5:40
IP Address....................................... 10.0.0.254
IP Netmask....................................... 255.0.0.0
IP Gateway....................................... 10.0.0.1
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. untagged
Quarantine-vlan.................................. 0
Physical Port.................................... 2
Primary DHCP Server.............................. 10.0.0.100
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... No
Guest Interface.................................. No
please help me.
On Fri, Feb 12, 2010 at 2:24 PM, leolaohoo <
Leo Laohoo Fri, 02/12/2010 - 01:05
  • Hall of Fame,
    2017 LAN, Wireless
Can you ping the Management IP Address?
Is HTTP enabled (by default HTTP is disabled but HTTPS is enabled)?
Have you tried HTTPS?
Arup Dutta Fri, 02/12/2010 - 01:09
Hi Leo,
i am able to ping this management ip 10.0.0.254 by console but not
my system and i tried both http:
ip and https:
System(Laptop) ip is 10.0.0.222 gateway 10.0.0.254 and also tried none.
On Fri, Feb 12, 2010 at 2:35 PM, leolaohoo <
Leo Laohoo Fri, 02/12/2010 - 01:16
  • Hall of Fame,
    2017 LAN, Wireless
Right, well I believe the link between the WLC and the switch should be a dot1q Trunk.
Arup Dutta Fri, 02/12/2010 - 01:24
hi,
my setup just like that,
WLC IS CONNECT MY SYSTEM BY A rj45 CABLE.
please tell network scenario so that i can access it by GUI interface.
On Fri, Feb 12, 2010 at 2:46 PM, leolaohoo <
Leo Laohoo Fri, 02/12/2010 - 01:29
  • Hall of Fame,
    2017 LAN, Wireless
Which port of the 2106 is your laptop connected to?
What is the subnet mask of your laptop?
Disable firewall on the client.
Arup Dutta Fri, 02/12/2010 - 01:31
hi,
port 2 is connected on my system.
subnet is 255.0.0.0
system firewall is disable
waiting for your response
On Fri, Feb 12, 2010 at 2:59 PM, leolaohoo <
