Compatibility with 4400 and 5500
Feb 12th, 2010
Folks,
I have a doubt, there is an existing setup of 4400 series controller. I would like to add more access points , which the current controller cannot accommodate, also client requires redundancy in the solution. I was wondering, if it is possible to add 5500 controller and configure one to one redundancy b/w 4400 controller and 5500 series.
Siddarth .
Marcus Johansson Fri, 02/12/2010 - 05:59
yes it should work just fine, just make sure you have the same version of software on both, i.e version 6.0.x!
George Stefanick Fri, 02/12/2010 - 15:26
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
I see no reason why you couldn't. But make sure you share the same code and update the
mobility group.
