Slow flow through between Inside and DMZ on a PIX
Answered Question
Feb 12th, 2010
Hello everyone,
Here's my setup:
PIX-515E Release 6.3
3 physical interface: IN, OUT, DMZ
I have a problem about the flow through between a PC on the inside and a pc on the DMZ.
The flow between the 2 machines is about 60kB in one direction and about 500kB in another.
I tested with different cables RJ45, switch and PC but the result is the same.
When I put the 2 PCs on the inside I have a throughput of about 10MB fairly reasonable.
For me it just my PIX, you have already encountered this problem? Is there a parameter to be added to allow better flow between certain interface?
Thank you in advance for your answers.
Rémi
Correct Answer by Kureli Sankar about 7 years 3 months ago
Remi,
Collect the output again and see if the counters increment.
If so may be try to change the setting to auto auto on both ends (switch and firewall) and see if the errors will go away.
sh int e0/0
do it for each interface and findout which interface is seeing errors.
-KS
Overall Rating: 5 (1 ratings)
p.mcgowan Fri, 02/12/2010 - 03:05
  • Bronze, 100 points or more
have you tested throughput between two
devices on the DMZ?
Remi49000 Fri, 02/12/2010 - 04:34
Thanks for your answer,
Yes I have tested throughput between two devices on the DMZ and the result is also correct (near 10MB)
If you have another idea..
Rémi
Kureli Sankar Fri, 02/12/2010 - 06:10
  • Cisco Employee,
sh int | i errors
do any of them show errors?
-KS
p.mcgowan Fri, 02/12/2010 - 06:39
Have you checked speed and duplex settings are fixed 100mb full duplex on clients switch ports and pix interface ports.
Are there any errors on pix interface ports?
Paul McGowan
Capita IT Services
Sent From Blackberry
Remi49000 Fri, 02/12/2010 - 07:10
Yes, all interfaces are fixed 100mb full duplex and switch too.
But:
sh int | i errors
    0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
    2232467 input errors, 1616434 CRC, 0 frame, 0 overrun, 1616434 ignored, 0 abort
    260 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
Correct Answer
Kureli Sankar Fri, 02/12/2010 - 07:16
  • Cisco Employee,
Remi,
sh int e0/0
-KS
Remi49000 Fri, 02/12/2010 - 07:33
Yes the counters increment in mode 100full
But in settings mode "auto" on the inside and DMZ now it's OK!!
Many thanks, throughput are great now !!
