Problem with VPN on SA520
pixteam2007
Hi, I would like your help why I have problem with vpn configuration with Shrewsoft to SA 520.
On Cisco appliance I have configured an VPN with ipsec user and PSK but when I try to connect I have in log:
2010-02-12 09:04:55: INFO:  Adding IPSec configuration with identifier "damorvpn" 2010-02-12 09:04:55: INFO:  Adding IKE configuration with identifer "myvpn" 2010-02-12 10:14:05: ERROR:  Could not find configuration for 217.x.y.z[500]
I have used the default parameter on Cisco and in vpn client I have used:
Authentication Method --> Mutual PSK+XAuth
Identification Type: FQDN --> local.com
Remote Identity: Any
..and all parameters are default.
On Shrewsoft I have:
config loaded for site 'myvpn'
configuring client settings ...
attached to key daemon ...
peer configured
iskamp proposal configured
esp proposal configured
client configured
local id configured
pre-shared key configured
bringing up tunnel ...
negotiation timout occurred
tunnel disabled
detached from key daemon ...
I very much hope in a your help, thanks.
Salvatore.
rtkoch1
I am having the same problem. I have not looked to deep into this as yet. The only difference is that I am using the SA 520W. Did you ever find a fix? If I find out anything I will post here?
sorry but I haven't found a solution for this problem, if possible do you use 5505 model.
Salvatore.
