Cisco ASA 5510 - VPN troubles
stjosephpines
I am setting up a new Cisco ASA 5510, I have the basic setup up and running but I am also needing to set up a VPN. However I am having some trouble getting this to work. When I connect using the Cisco VPN client I get Secure VPN Connection terminated locally by the Client. Reason 412: The remote peer is no longer responding. I have turned off all firewalls and tried from multiple connections and machines. I am including the logs from the client and a copy of the config.
Here is a copy of my ASA Config
: Saved
ASA Version 8.0(2)
hostname SJPFW001
enable password encrypted
names
interface Ethernet0/0
description inside interface
nameif inside
security-level 100
ip address 192.168.1.6 255.255.0.0
interface Ethernet0/1
description DMZ Interface
shutdown
nameif DMZ
security-level 50
ip address 172.16.0.253 255.255.0.0
interface Ethernet0/2
description Embarq Interface
nameif outside1
security-level 0
ip address xxx.xxx.93.158 255.255.255.252
interface Ethernet0/3
description TWC Interface
nameif outside2
security-level 0
ip address xxx.xxx.97.44 255.255.255.248
interface Management0/0
nameif management
security-level 100
ip address 172.22.22.1 255.255.0.0
management-only
passwd encrypted
ftp mode passive
object-group service vpn tcp
port-object eq 10000
object-group network group-inside-vpnclient
description All inside accessible networks
network-object 192.168.1.0 255.255.255.0
access-list outside-entry extended permit icmp any any echo-reply
access-list outside-entry extended permit icmp any any time-exceeded
access-list outside-entry extended permit icmp any any unreachable
access-list outside-entry extended permit tcp any host xxx.xxx.92.193 eq 3389
access-list outside-entry extended permit tcp any host xxx.xxx.93.158 eq 3389
access-list outside-entry extended permit tcp any host xxx.xxx.93.158 eq www
access-list outside-entry extended permit tcp any host xxx.xxx.93.158 eq https
access-list outside-entry extended permit tcp any host xxx.xxx.193 eq smtp
access-list outside-entry extended permit tcp any host xxx.xxx.92.193 eq https
access-list outside-entry extended permit tcp any host xxx.xxx.92.193 eq 465
access-list outside-entry extended permit tcp any host xxx.xxx.93.158 eq 3101
access-list outside-entry extended permit tcp any host xxx.xxx.92.194 eq smtp
access-list outside-entry extended permit tcp any host xxx.xxx.92.194 eq https
access-list outside-entry extended permit tcp any object-group vpn xxx.xxx.93.156
255.255.255.252
access-list inside_nat0_outbound extended permit ip any 192.168.100.0 255.255.25
5.192
access-list acl-vpnclient extended permit ip object-group group-inside-vpnclient
any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu DMZ 1500
mtu outside1 1500
mtu outside2 1500
mtu management 1500
ip local pool vpnpool_ip 192.168.100.20-192.168.100.40 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-602.bin
no asdm history enable
arp timeout 14400
global (outside1) 1 interface
global (outside2) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 192.168.0.0 255.255.0.0
static (inside,outside1) tcp interface 3389 192.168.0.12 3389 netmask 255.255.25
5.255
static (inside,outside1) tcp interface 3101 192.168.0.15 3101 netmask 255.255.25
5.255
static (inside,outside1) tcp interface www 192.168.1.17 www netmask 255.255.255.
255
static (inside,outside1) 67.238.92.193 192.168.1.4 netmask 255.255.255.255
static (inside,outside1) 67.238.92.194 192.168.1.20 netmask 255.255.255.255
access-group outside-entry in interface outside1
route outside1 0.0.0.0 0.0.0.0 67.238.93.157 1 track 1
route outside2 0.0.0.0 0.0.0.0 24.172.97.41 2
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 172.22.22.0 255.255.255.0 management
http 0.0.0.0 0.0.0.0 outside1
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sla monitor 123
type echo protocol ipIcmpEcho 67.238.93.157 interface outside1
num-packets 3
frequency 10
sla monitor schedule 123 life forever start-time now
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128
-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256
-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside1_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside1_map interface outside1
crypto isakmp enable outside1
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
track 1 rtr 123 reachability
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect icmp
service-policy global_policy global
webvpn
enable outside1
group-policy SJP internal
group-policy SJP attributes
dns-server value 192.168.1.3
vpn-tunnel-protocol IPSec l2tp-ipsec webvpn
default-domain value sjp.org
webvpn
url-list none
username sjpadm password encrypted encrypted privilege 0
username sjpadm attributes
vpn-group-policy SJP
tunnel-group SJP type remote-access
tunnel-group SJP general-attributes
address-pool vpnpool_ip
default-group-policy SJP
tunnel-group SJP webvpn-attributes
hic-fail-group-policy SJP
nbns-server 192.168.1.3 timeout 2 retry 2
tunnel-group SJP ipsec-attributes
pre-shared-key *
tunnel-group SJP_VPN type remote-access
tunnel-group SJP_VPN general-attributes
prompt hostname context
Cryptochecksum:fce8c724d0af5f945fbc09ecc3596752
: end
And there are the logs
Cisco Systems VPN Client Version 5.0.06.0160
Copyright (C) 1998-2009 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 3
6 11:14:47.254 02/10/10 Sev=Info/4 CM/0x63100002
Begin connection process
7 11:14:47.441 02/10/10 Sev=Info/4 CM/0x63100004
Establish secure connection
8 11:14:47.441 02/10/10 Sev=Info/4 CM/0x63100024
Attempt connection with server "67.238.93.158"
9 11:14:47.597 02/10/10 Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with 67.238.93.158.
10 11:14:47.738 02/10/10 Sev=Info/4 IKE/0x63000001
Starting IKE Phase 1 Negotiation
11 11:14:47.847 02/10/10 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to 67.238.93.158
12 11:14:47.863 02/10/10 Sev=Info/4 IPSEC/0x63700008
IPSec driver successfully started
13 11:14:47.863 02/10/10 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
14 11:14:53.126 02/10/10 Sev=Info/4 IKE/0x63000021
Retransmitting last packet!
15 11:14:53.126 02/10/10 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (Retransmission) to 67.238.93.158
16 11:14:58.623 02/10/10 Sev=Info/4 IKE/0x63000021
17 11:14:58.623 02/10/10 Sev=Info/4 IKE/0x63000013
18 11:15:04.120 02/10/10 Sev=Info/4 IKE/0x63000021
19 11:15:04.120 02/10/10 Sev=Info/4 IKE/0x63000013
20 11:15:09.617 02/10/10 Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion (I_Cookie=6EEEFA8407046028 R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
21 11:15:10.616 02/10/10 Sev=Info/4 IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=6EEEFA8407046028 R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
22 11:15:10.616 02/10/10 Sev=Info/4 CM/0x63100014
Unable to establish Phase 1 SA with server "67.238.93.158" because of "DEL_REASON_PEER_NOT_RESPONDING"
23 11:15:10.616 02/10/10 Sev=Info/5 CM/0x63100025
Initializing CVPNDrv
24 11:15:10.663 02/10/10 Sev=Info/6 CM/0x63100046
Set tunnel established flag in registry to 0.
25 11:15:10.710 02/10/10 Sev=Info/4 IKE/0x63000001
IKE received signal to terminate VPN connection
26 11:15:11.475 02/10/10 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
27 11:15:11.475 02/10/10 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
28 11:15:11.475 02/10/10 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
29 11:15:11.475 02/10/10 Sev=Info/4 IPSEC/0x6370000A
IPSec driver successfully stopped
Collin Clark
You're failing at IKE Phase 1 which typically means a mismatch in the passwords. Here's a great troubleshooting guide that will help.
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml
Hope it helps.
