threat-detection configuration on ASA5520 Version 8.2(1)
Feb 12th, 2010
I want to get statistics about how often I am under attacks and the nature of the attacks.
I read many documents about how to activate threat-detection in ASA v8. For this, I need to type the following command: threat-detection basic-threat. Unfortunately I don't have this command and I don't have "show threat-detection statistics port/protocols" either.
The only available commands are: "threat-detection statistics tcp-intercept ...".
I am in a ASA5520 in version 8.2(1) in configure terminal.
Do you have any Idea why these commands are not available?
Many thanks!
atosorigin Fri, 02/12/2010 - 06:58
Thanks for your reply. Unfortunately I already saw this documentation.
As I said these commands should be available but for any reason, I don't know why they don't appear.
Here you can see that I have only the threat-detection statistics command available:
SPGLO0001FW/BACK(config)# threat-detection ?
configure mode commands/options:
  statistics  Keyword to configure statistics of threat detection
What could be the reason? Is a license needed?
If it helps, below the show version result:
SPGLO0001FW/BACK# sh ver
Cisco Adaptive Security Appliance Software Version 8.2(1)
Detected an old ASDM version.
You will need to upgrade it before using ASDM.
Compiled on Tue 05-May-09 22:45 by builders
SPGLO0001FW up 28 days 1 hour
failover cluster up 28 days 1 hour
Hardware:   ASA5520
Licensed features for this user context:
Failover                     : Active/Active
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
GTP/GPRS                     : Disabled
Botnet Traffic Filter        : Disabled
