overlay-dn configuration over two CME routers
jyoung
I currently have CME 4.2 running at our headquarter location.  Because 4.2 does not support broadcast hunt groups, I have been using the overlay-dn method to have department extensions ring on multiple phones.  I am prepping for another office opening in another location in which I will be using CME 7.0 and a SIP trunk over a VPN.  I would like to avoid upgrading the headquarters router because it also is the gateway for an IPCC call center which was a bear to set up initially with CME.  Can anyone think of a way to have a department DN ring at both sites?  I know I could upgrade the headquarters CME to gain the use of broadcast hunt groups but again, I am looking to avoid that if possible.
Thanks in advanced.
paolo bevilacqua
If I was you, I would upgrade without a doubt.
Anyway, I wrote a TCL/IVR script that allows blast calling:
http://www.ciscoxmlservices.com/it/tcl--ivr-scripts
Or you can contact me at the address rpesent in my profile
