Filter to show APs with clients.
Answered Question
How do I  create a filter by AP on my 4400 series WLC to show all the clients associated to those APs?  Thanks in advance.
Correct Answer by braggb001 about 6 years 11 months ago
Samantha,
     This may be different depending on the version of code you are running, but this would be how you do it when running ver. 4.2.176.0
  1. Web into the Controller
  2. With the "Monitor" tab selected (home screen) click the "Clients" link on the left.
  3. Near the top click the "Change Filter" link
  4. Check the box next to "AP Name"
  5. Enter the name of the Access-Point you would like to filter by
That should be it.  Hope this helps.
Overall Rating: 5 (1 ratings)
Correct Answer
braggb001 Fri, 02/12/2010 - 08:07
Samantha,
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
