CFS : how to disable application ? nexus 5000
Feb 12th, 2010
1. Could you please help me out here. I am setting up syslog on Nexus switches and running into problems (error messages at bottom)
On Nexus 5000, I am trying to disable CFS distribution for application SYSLOGD, but do not find a command to do that.
Why I want to do that ?
With CFS enabled for syslogd, 'use-vrf' option is not allowed in the command 'logging server 167.54.254.23 6 ' and by default syslogd uses vrf management whereas I want it to use vrf default.
2. Also, any idea why this message pops up ?
CLIC-6-EXIT_CONFIG: Configured from 1 by systest
2010 Feb 12 10:40:13.308 ked1.dcacc.n01 LOG-3-SYSTEM_MSG: Syslog could not be send to serv
er(167.54.254.23) : No route to host
2010 Feb 12 10:40:46.162 ked1.dcacc.n01 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty ....
2010 Feb 12 10:40:46.170 ked1.dcacc.n01 LOG-3-SYSTEM_MSG: Syslog could not be send to serv..) : No route to host
2010 Feb 12 10:40:46.170 ked1.dcacc.n01 11244]: CLIC-6-EXIT_CONFIG: Configured from 1 by systest
2010 Feb 12 10:40:46.181 ked1.dcacc.n01 snmpd: snmpd: send_trap: Failure in sendto (No route to host)
2010 Feb 12 10:40:46.183 ked1.dcacc.n01 last message repeated 2 times
2010 Feb 12 10:40:46.183 ked1.dcacc.n01 snmpd: NETWORK- UNREACHABLE
Related Content
