configure 881w wireless ap - first timer
danieldenson
I am running an 881W on 12.4(20)T3
I can't figure out how to configure the internal access point.  All the guides that I see out there say to log in via service-module wlan-ap but this is what I get:
tciao#service-module wlan-ap 0 session
IP address needs to be configured on interface wlan-ap0
tciao#
I cannot set an IP on wlan-ap0
tciao(config)#interface wlan-ap 0
The wlan-ap 0 interface is used for managing the embedded AP.
Please use the "service-module wlan-ap 0 session" command to console into the embedded AP
any help would be greatly appreciated.
p.s. I also tried to config it with CCP and I can get logged in but any attempt to setup a wireless network seems to have no affect and I cant get to the APs web interface.
tciao#service-module wlan-ap 0 status
Service Module is Cisco wlan-ap0
Service Module supports session via TTY line 2
Service Module is in Steady state
Service Module reset on error is disabled
Service Module heartbeat-reset is enabled
Getting status from the Service Module, please wait..
  Image path       = flash:/ap801-k9w7-mx.124-10b.JDA3/ap801-k9w7-mx.124-10b.JDA3
  System uptime    = 0 days, 0 hours, 8 minutes, 27 seconds
Jon Marshall
Daniel
The message you get back above is normal when you go to configure an IP. When the router returns to the prompt what does the prompt look like ie.
tciao(config)#
or
tciao(config-if)#
it should be the second one ie. tciao(config-if)#
If so then you simply then configure an ip address eg.
tciao(config-if)# ip address 192.168.5.1 255.255.255.0
Use this config guide to get started -
881 wireless config
Jon
Jon Marshall
Daniel
tciao(config)#
or
tciao(config-if)#
881 wireless config
Jon
I ended up setting the BVI1 interface address in CCP.  I then telnetted from my PC to that address.  I had to login with cisco/cisco even though I had already setup a different username.  I then had to enable the secure http server before I could connect to the web interface.  I still have not set the IP address of wlan-ap 0 and cannot use service-module wlan-ap 0 session to connect.
I am worried that by setting that I will break something.
Okay, not sure what else to say. The config guide clearly shows the message you are getting.
Jon
ok Jon, thanks for your help.  I appreciate it.
