The ACL doesn´t work with the same security level
Feb 12th, 2010
I have an ASA, with the same security level in all interfaces. I define an ACL in the interface A. When I origin a new connection from interface B to web server (in side of interface A) , If I try to deny this access in the ACL apply at the interface A, the ACL is not working well I don´t see any matchs but if I configure a capture I see the flow correctly.
Do you have any idea or what could be happens?
If you want more details, please let me know.
Thanks for your help.
Emilio  Borbolla
emilio.borbolla Fri, 02/12/2010 - 11:23
Sorry, I forget to comment that, I am using  "same-security-traffic permit inter-interface" command.
Collin Clark Fri, 02/12/2010 - 12:22
  • Purple, 4500 points or more
Can you post the relevant part of the ACL and the access-group configuration lines?
emilio.borbolla Fri, 02/12/2010 - 12:38
The coneccion begins from IP 200.4.145.97 in R5 interface to IP 200.33.150.202, at the begin I undertand the syc pass, but the aswer should be dropp
interface Ethernet0
speed 100
duplex full
nameif R5
security-level 100
ip address 204.124.107.254 255.255.255.252
interface Ethernet1
speed 100
duplex full
nameif Reduno
security-level 100
ip address 10.105.191.81 255.255.255.248
access-list 110 line 1 extended permit ip 204.124.106.128 255.255.255.128 host 201.147.131.21
access-list 110 line 2 extended permit ip 204.124.106.128 255.255.255.128 204.124.107.0 255.255.255.0
access-list 110 line 3 extended permit ip 204.124.106.128 255.255.255.128 204.124.104.240 255.255.255.248
access-list 110 line 4 extended permit ip 204.124.106.128 255.255.255.128 200.4.145.0 255.255.255.0
access-list 110 line 5 extended permit tcp host 200.4.155.230 204.124.104.240 255.255.255.248
access-list 110 line 6 extended permit tcp host 200.4.155.230 200.4.145.0 255.255.255.128
access-list 110 line 7 extended permit tcp host 200.33.150.202 204.124.104.240 255.255.255.248
access-list 110 line 8 extended deny tcp host 200.33.150.202 200.4.145.0 255.255.255.128
access-group 110 in interface Reduno
access-list ebg line 1 extended permit ip host 200.33.150.202 200.4.145.0 255.255.255.128
FWPIX525-NOC# sh capture
FWPIX525-NOC# sh capture captura
643 packets captured
   1: 16:38:21.925611 200.33.150.202.80 > 200.4.145.97.1063: S 3203090713:3203090713(0) ack 2654701753 win 16384
   2: 16:38:21.954052 200.33.150.202.80 > 200.4.145.97.1063: P 3203090714:3203091080(366) ack 2654702155 win 65133
   3: 16:38:21.990488 200.33.150.202.80 > 200.4.145.97.1063: P 3203091080:3203091546(466) ack 2654702565 win 64723
   4: 16:38:22.017821 200.33.150.202.80 > 200.4.145.97.1063: . 3203091546:3203092806(1260) ack 2654702976 win 64312
Collin Clark Fri, 02/12/2010 - 12:43
Can you please post the ACL assigned to R5? The access-group config line would help too.
emilio.borbolla Fri, 02/12/2010 - 14:31
Thanks Clark,
I don´t remmember about the out ACL that I have in the Reduno interface, maybe my ACL should apply there...
access-group master in interface R5
access-group 105 out interface Reduno
access-list master extended permit ip any any
FWPIX525-NOC# sh run access-list 105
access-list 105 extended permit ip 204.124.104.240 255.255.255.240 any
access-list 105 extended permit ip 200.4.145.0 255.255.255.128 any
access-list 105 extended permit ip 204.124.107.224 255.255.255.240 any
access-list 105 extended permit ip host 201.147.131.21 any
access-list 105 extended permit tcp host 204.124.107.131 204.124.106.0 255.255.255.0 eq ftp
access-list 105 extended permit tcp host 204.124.107.131 204.124.106.0 255.255.255.0 eq ftp-data
access-list 105 extended permit tcp host 204.124.107.131 200.4.155.0 255.255.255.0 eq ftp
access-list 105 extended permit tcp host 204.124.107.131 200.4.155.0 255.255.255.0 eq ftp-data
access-list 105 extended permit tcp host 204.124.107.131 200.4.157.0 255.255.255.0 eq ftp
access-list 105 extended permit tcp host 204.124.107.131 200.4.157.0 255.255.255.0 eq ftp-data
access-list 105 extended permit tcp host 204.124.107.131 200.33.137.0 255.255.255.0 eq ftp
access-list 105 extended permit tcp host 204.124.107.131 200.33.137.0 255.255.255.0 eq ftp-data
access-list 105 extended permit tcp host 204.124.107.131 200.33.150.0 255.255.255.0 eq ftp
access-list 105 extended permit tcp host 204.124.107.131 200.33.150.0 255.255.255.0 eq ftp-data
access-list 105 extended permit tcp host 204.124.107.133 host 192.100.183.178 eq ftp
access-list 105 extended permit tcp host 204.124.107.133 host 192.100.183.178 eq ftp-data
access-list 105 extended permit tcp host 204.124.107.133 host 192.100.183.178 eq telnet
access-list 105 extended permit tcp host 204.124.107.133 host 192.100.183.178 gt 1024
access-list 105 extended permit tcp host 204.124.107.133 host 192.100.183.178 eq smtp
access-list 105 extended permit udp host 204.124.107.133 any eq domain
access-list 105 extended permit udp host 204.124.107.133 any gt 1024
access-list 105 extended permit tcp host 204.124.107.133 any gt 1024
access-list 105 extended permit udp host 204.124.107.131 any eq domain
access-list 105 extended permit udp host 204.124.107.131 any gt 1024
access-list 105 extended permit tcp host 204.124.107.151 host 192.100.183.104 eq www
access-list 105 extended permit tcp host 204.124.107.151 host 192.100.183.104 gt 1024
access-list 105 extended permit tcp host 204.124.107.133 host 192.100.183.104 eq www
access-list 105 extended permit tcp host 204.124.107.133 host 192.100.183.104 gt 1024
access-list 105 extended permit tcp host 204.124.107.146 host 192.100.183.104 eq www
access-list 105 extended permit tcp host 204.124.107.146 host 192.100.183.104 gt 1024
access-list 105 extended permit tcp host 204.124.107.158 any eq smtp
access-list 105 extended permit ip host 204.124.107.134 any
access-list 105 extended permit ip host 204.124.107.35 any
access-list 105 extended permit ip host 192.100.183.254 host 192.100.183.253
access-list 105 extended permit ip 204.124.107.208 255.255.255.240 host 192.100.183.183
access-list 105 extended permit ip 204.124.107.88 255.255.255.248 host 192.100.183.183
access-list 105 extended permit ip 152.148.1.0 255.255.255.0 host 192.100.183.183
access-list 105 extended permit ip host 204.124.107.139 host 192.100.183.183
access-list 105 extended permit ip host 204.124.107.141 host 192.100.183.183
access-list 105 extended permit ip host 204.124.107.70 host 192.100.183.183
access-list 105 extended permit ip host 204.124.107.148 host 192.100.183.183
access-list 105 extended permit ip 172.28.1.0 255.255.255.0 host 192.100.183.183
access-list 105 extended permit ip 204.124.107.208 255.255.255.240 host 192.100.183.161
access-list 105 extended permit ip 204.124.107.88 255.255.255.248 host 192.100.183.161
access-list 105 extended permit ip 152.148.1.0 255.255.255.0 host 192.100.183.161
access-list 105 extended permit ip host 204.124.107.139 host 192.100.183.161
access-list 105 extended permit ip host 204.124.107.141 host 192.100.183.161
access-list 105 extended permit ip host 204.124.107.70 host 192.100.183.161
access-list 105 extended permit ip host 204.124.107.148 host 192.100.183.161
access-list 105 extended permit ip 172.28.1.0 255.255.255.0 host 192.100.183.161
access-list 105 extended permit tcp host 204.124.107.2 host 192.100.183.98
access-list 105 extended permit tcp host 204.124.107.3 host 192.100.183.98
access-list 105 extended permit tcp host 204.124.107.116 host 192.100.183.178 eq smtp
access-list 105 extended deny ip 189.254.64.0 255.255.255.0 any
access-list 105 extended deny ip any 192.100.183.176 255.255.255.240
access-list 105 extended deny ip any 192.100.183.96 255.255.255.240
access-list 105 extended deny ip any 192.100.183.32 255.255.255.240
access-list 105 extended deny ip any host 200.4.157.56
access-list 105 extended permit ip 152.148.1.0 255.255.255.0 172.30.38.0 255.255.255.0
access-list 105 extended permit ip 152.148.1.0 255.255.255.0 10.254.3.0 255.255.255.0
access-list 105 extended permit ip 152.148.1.0 255.255.255.0 host 212.179.43.225
access-list 105 extended permit ip 152.148.1.0 255.255.255.0 host 212.179.43.228
access-list 105 extended permit ip 204.124.107.0 255.255.255.0 any
access-list 105 extended permit ip 172.28.1.0 255.255.255.0 any
access-list 105 extended permit ip 172.16.1.0 255.255.255.0 any
access-list 105 extended permit ip host 10.105.191.81 host 10.105.191.86
FWPIX525-NOC#
Collin Clark Mon, 02/15/2010 - 06:14
Since you have ACLs both in and out, you will have to go through and verify that it's allowed through both.
Related Content
