Connecting N7K and 3560E - Fiber Link
Feb 12th, 2010
How can we connect 3560E switches with 1G uplink to 32 10G module using multimode fiber? In other words, can we connect SFP with SFP+ ? What would be the result?
Many thanks,
Yazeed
Jerry Ye Fri, 02/12/2010 - 14:28
  • Cisco Employee,
You can't connect a 1GB port to a 10GB port. It will not work.
HTH,
jerry
yaltal Sat, 02/13/2010 - 03:21
Many thanks Jerry.
Is there a converter or adapter that will help achiveing that? i.e connect 1G with 10G and works as 1G link.
Cheers,
Yazeed
Jerry Ye Sat, 02/13/2010 - 07:07
  • Cisco Employee,
Certain 3560E has 2 Twingig converters to convert a 10GE into 2x 1GE. If you remove the Twingig converter, you can insert 10GE X2 optic and connect the 3560E and N7K with 10GE connection. In another word, I am not aware of any converter to change the N7K's 10GE to 1GE, other than getting the 1GE line card on the N7K.
HTH,
jerry
