NAC Timers
Feb 12th, 2010
the default session timeout timers for NAC is :
Role                          Session timeout
unauthenticated Role           Disabled
Temporary Role                    4
Quarantine Role                    4
what is the ordering of applying these roles and timers once the user try to login to the PC ?
-before authentication
-after authentication & PC meets security requirements
-after authentication & PC doesn't meets security requirements
Faisal Sehbai Fri, 02/12/2010 - 14:52
  • Gold, 750 points or more
Hany,
The only timer to worry about is the Temporary Role one. That is used if you're using the agent, and are missing some requirements. This time is allowed for you to remediate (by default 4 minutes) Generally customers increase that so the clients can get remediated.
The quarantine timer only applies if you're using nessus scanning, and the unauthenticated timer only for the unauthenticated role.
HTH,
Faisal
hany_ibrahim Sat, 02/13/2010 - 06:08
OK , but what about the ordering of excution as i listed ?
Faisal Sehbai Sat, 02/13/2010 - 19:33
Hany,
The order is the same as you listed. When PC is unauthenticated, the unauthenticated timers apply. When it's doing posture and remediation the Temporary role timers apply. If you're doing Nessus scanning, then the Quarantine timers apply.
HTH,
Faisal
