02-12-2010 04:06 PM
I would like to know:
How can I replace device-alias pWWN using command line?
How can I add a new pWWN to device-alias using command line?
Thanks.
02-16-2010 04:15 PM
up-up
nobody?
02-23-2010 12:54 PM
Creating Device Aliases
To a create a device alias in the pending database, perform this task:
SUMMARY STEPS
1.
switch# configuration terminalswitch(config)# device-alias databaseswitch(config-device-alias-db)# device-alias name device-name pwwn pwwn-id
4.
switch(config-device-alias-db)# no device-alias name device-name5.
switch(config-device-alias-db)# device-alias rename old-device-name new-device-nameDETAILED STEPS
Command or Action Purpose
Step 1
Step 2
device-alias name
device-name
pwwn pwwn-idStep 3
simultaneously locks the fabric as this is the first-issued
device alias configuration command.
Removes the device name for the device that is identified by
its pWWN.
device-name
Step 4
device-alias rename Renames an existing device alias with a new name.
Step 5
Example of Creating a Device Alias
To display the device alias configuration, use the
show device-alias name command:
switch#
show device-alias name x
device-alias name x pwwn 21:01:00:e0:8b:2e:80:93
switch(config)# device-alias database Enters the pending database configuration submode.Specifies a device name for the device that is identified by
its pWWN. Starts writing to the pending database and
switch# configuration terminal Enters configuration mode.2.
3.
