Can only ping router when SSL VPN connected
The problem started after I upgraded my 2811 router to IOS 15 (from 12.4xxx).
I had to reinstall VPN AnyConnect.
Router IP:
Connecting to VPN gives me
Now I can ping, but no more any other IP at the same subnet at all.
I have done a diff of the old config and the new one and can't find any difference on the webvpn parts and access-lists/NAT.
Any suggestions?
I did one last try to upgrade to even newer IOS, ver.15.1-1.XB.
Then the webvpn context is impossible to get inservice (whatever hard I try I never get it away from "no inservice").
Doing no change at all else than going back to 12.4(15)T9 again, everything is normal once more...
To me it seems like AnyConnect on anything newer than 12.4(15)T9 does not work very well... Is there anyone out there running AnyConnect SSL successfully on the new 15.x versions?
