What is the default idle TCP session time out in FWSM
Answered Question
Feb 13th, 2010
Hi All,
I would like to know what is the default TCP idle session time out in FWSM and if i want to increase this timer what can be impact and security reasons and how can i do also ? and is there any setting in firewall to increase a idle timeout setting for specific port.
Ganesh.H
Overall Rating: 5 (1 ratings)
Jon Marshall Sat, 02/13/2010 - 03:55
ganeshh.iyer wrote:
Hi All,
Ganesh.H
Ganesh
It should be one hour. You can view the current timeout settings with "sh timeout" or "sh running-config timeout".
Prior to 3.x code the timeout setting was global so if you changed the TCP timeout it affected all tcp connections. However with v3.x code you can now use Modular Policy Framework to set timeouts for specific ports/IP addresses -
FWSM MPF
Jon
Ganesh Hariharan Sun, 02/14/2010 - 22:03
Ganesh
FWSM MPF
Jon
Jon
Yes my query is cleared just can you provide some other document also for port based increasing the idle time out session in firewall.
Ganesh.H
