4402 we have two physical port, do the port 1 can be used for management & and for vlan config to
Answered Question
Feb 13th, 2010
In 4402 we have two port, I am using port -1 for management 172.16.124.10 [ vlan 1], do I use the same port -1 for VLAN 101 also for IPT Voice network [ 172.16.125.10] as trunk configured in switch or do I use only port-2 for other vlan configuration.
Port -1 is reseverd for management alone or do we can use port -1 for management + other vlan configuration.
Following the below doc for VLANs on Wireless LAN Controllers Configuration:
http://www.cisco.com/application/pdf/paws/68100/wlan_controllers_vlans.pdf
Correct Answer by George Stefanick about 7 years 5 months ago
"0" assumes untagged and as such your switch will need to be native for that vlan. Any other number used will be tagged and as such a trunk needs to be appllied to the switch .q.
Why? That is a great question and one i have had as well. I have asked many Cisco engineers and the anwser i got was,"its recommend pratice. BUT you can tag the traffic".
Personally, I have deployments set up each way and I havent had any issues.
I hope that helps a little ...
Correct Answer by Leo Laohoo about 7 years 5 months ago
If memory serves me correct, default VLAN for the WLC is "0" which is VLAN 1 on a switch.  Can you turn Management interface to VLAN "0" on the WLC?
Overall Rating: 5 (2 ratings)
Leo Laohoo Sat, 02/13/2010 - 14:41
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hey Balamurugan,
You can LAG port 1 & 2.  Together you can run a number of VLANs into them although I only have ONE active link.
Be aware that "bridging" a WLC is not supported.  When I mean bridge it looks like this:
switch 1 < --- > WLC Port 1 === WLC Port 2 < --- > Switch 2
Hope this works.
BALAMURUGAN SINGARAM Sat, 02/13/2010 - 20:47
Thanks a lot for the reply, My set up as follows, I am using physical port -1 as management interface in vlan 1 172.16.125.10, and create dynamic interface vlan 111 172.16.124.10 for Vlan 111 network associated with physical port -1, I am able to ping 172.16.124.10 form switch, but I am not able to ping 172.16.125.10 from switch. The switch configuration for port -1 as follows:
int gig 0/1
switchport
switchport trunk allowed vlan 1, 111
switchport mode trunk
no shut.
Please update me what I am missing to have connectivity between my swithc and dynamic interface vlan 111.
Correct Answer
Leo Laohoo Sat, 02/13/2010 - 22:21
  • Hall of Fame,
    2017 LAN, Wireless
Leo Laohoo Sat, 02/20/2010 - 17:33
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the rating.
BALAMURUGAN SINGARAM Sat, 02/20/2010 - 20:04
It is must that we should make management vlan to 0, even if I have management vlan 111 and I am able to create multiple vlan and it is working fine, but the document says the management vlan should be untagged, please light me why the management vlan should be untagged, In my topology I have try management as TAG and UNTAG vlan both the case it works fine.
Correct Answer
George Stefanick Sun, 02/21/2010 - 19:58
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
