MLP Config Question
Feb 9th, 2010
We have been configuring and working with multilink ppp for quite some time now and in a lot of different scenarios. One question i have always had is related to syntax and config choice: multilink interface configuration Vs virtual-template configuration. I know it is very common for us, as well as for many other cisco partners, to use a configuration similar to the following:
interface multilink number
ip address address mask
ppp multilink
ppp multilink group number
interface serial number1
no ip address
encapsulation ppp
ppp multilink
interface serial number2
no ip address
encapsulation ppp
ppp multilink
I have heard this referred to as "multilink bundle configuration" or "multilink interface configuration" and it functions fine on a single unit. Apparently though, at least from what I'm seeing in the config docs, this is targetted towards Distributed MLP.
On a single unit, the IOS 15.0 Dial Configuration Guide calls for the use of virtual-templates:
interface loopback number
ip address number mask
multilink virtual-template number
interface virtual-template number
ip unnumbered loopback number
ppp multilink
no ip address
encapsulation ppp
ppp multilink
no ip address
encapsulation ppp
ppp multilink
Either configuration works fine on a single router. I'm sure there are operational differences between the two but I've never really run into a situation where a particular features does or does not work with either one. This is not really a problem, just a curiousity. Any insight would be greatly appreciated.
Thanks.
