Troubles with Regex on ASA
jhubel
I've been studying how inspect policy maps work on an ASA, and I come across the part where they talk about  blocking content using regex expressions.  I see that there are plenty  of examples published by Cisco (and many threads on various discussion boards) and I also see that there is a widly  published syntax for regular expressions.  All of this make sense to me  so far.  But, then I tried to configure this feature on my ASA, which has  proven to be much harder than it should be.
First, I  started on version 7.2(4).  I configured it exactly as they said and it didn't work, so I upgraded to 8.0(4) and the same thing occured.  Now, I'm running 8.2(2) and I'm bumping into the same problem.  Has anyone had such issues with this?  Let me show you what I'm doing:
ciscoasa(config)# sho run regex
regex testa "a\.com"
ciscoasa(config)# test regex a.com testa
INFO: Regular expression match failed.
ciscoasa(config)# test regex acom testa
ciscoasa(config)# test regex a\.com testa
ciscoasa(config)#
regex cisco_website "\.cisco\.com"
ciscoasa(config)# test regex www.cisco.com cisco_website
ciscoasa(config)# test regex .cisco.com cisco_website
ciscoasa(config)# test regex cisco.com cisco_website
ciscoasa(config)#
regex cisco_website ".*\.cisco\.com"
ciscoasa(config)#
regex file1 ".*[fF][iI][lL][eE][1]\.[tT][xX][tT].*"
ciscoasa(config)# test regex file12.txt file1
INFO: Regular expression match succeeded.
ciscoasa(config)# test regex file1txt file1
ciscoasa(config)# test regex file2txt file1
ciscoasa(config)# test regex file21txt file1
ciscoasa(config)# test regex file12txt file1
ciscoasa(config)# test regex blahfile1.blah.txtblah file1
ciscoasa(config)#
ciscoasa(config)# regex r-facebook www\.facebook\.com
ciscoasa(config)# test regex www.facebook.com r-facebook
ciscoasa(config)# regex r-facebook facebook
ciscoasa(config)# regex r-facebook .*facebook.*
ciscoasa(config)#
So, I have the regex expressions configured exactly as they should, but when I use the "test regex" feature, stuff doesn't match when it should and it does match when it shouldn't.
Any help is appreciated.
Jeff
Kureli Sankar
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080940e04.shtml
5505(config)# test regex http://a.com a\.com
5505(config)#
It works...
-KS
Kureli Sankar
5505(config)#
It works...
-KS
Ahh, I see what I've done.  I thought the "test regex" command referenced the regex that I had already configured, not the actual expression on the "test regex" line.  I expected it to work like testing a voice dial peer, but I'm set straight now.
Thanks for your help.
Jeff
