1121 Stand alone AP WPA2 config guide
Feb 13th, 2010
I am trying to upgrade a stand alone 1121 AP's (bridging, not controlled by a WLC) security config from WEP to WPA2.
I found this guide for the 1310...
But this 1121 menus do not match and I can not find one after a good hour of searching. Does anyone know where I can find a config guide for it?
Thank you!
cventici Sun, 02/14/2010 - 05:02
I have cli access as well if needed but would still need a config guide as I am not familiar with these devices.
Thank you.
Leo Laohoo Sun, 02/14/2010 - 13:21
I recommend you try configuring using CLI.  Unfortunately the business units that are responsible for updating outdated documents have been doing a "bang-up" job.  If you are able to successfully configure WPA2, then I recommend you rate that page appropriately so they (the Cisco business unit) can update the documents.
cventici Fri, 02/19/2010 - 18:26
I see that I can use Migration mode to have both WEP and WPA on the same AP.
I further see that I can use mixed mode so that I have both WPA and WPA2 at the same time.
Does anyone know if I can use both tools to have all 3 encryption types at the same time?
Trending Topics - Security & Network
