Virtual IP PBX
Feb 13th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:Arial; mso-bidi-theme-font:minor-bidi;}
I have a query regarding Virtual IP PBX,my Question is
1.Can v use a Carrier grade network platform(SIP based communication) that serves a Virtual hosted IP PBX over the Internet/MPLS cloud using SIP which communicates with the Cisco IP phones & PSTN gateways, thereby eliminating the need for a PBX or IP PBX on customer premises?
2.If yes, then what is exact procedure?
Looking forward 4 ur prompt response ASAP.
Paolo Bevilacqua Sun, 02/14/2010 - 06:03
You can do that but is poor solution, because you will never have the full features and control that you have with a local device, that is also cheap and effective like a CME router.
Moreover, if the Internet circuit fails, none of the telephones will work. That is bad.
