NAC image 4.1.3 to 4.7.2 upgtrade procedures
Feb 14th, 2010
Hi all,
Could anyone help me to get the step by step procedures for NAC upgrade from 4.1.3 to 4.7.2. I know that we have to upgrade to interim release 4.5(x) then to 4.7.2.
Thx
swami
Ganesh Hariharan Sun, 02/14/2010 - 03:31
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi all,
Thx
swami
Hi Swami,
Check out the below link hope it help !!
http://ciscosystems.com/en/US/docs/security/nac/appliance/release_notes/47/47rn.html#wp1033285
If helpful do rate the post !!
Ganesh.H
arumugasamy Mon, 02/15/2010 - 12:41
Genesh,
Thanks for your info.
I already copied 4.6.1 interim release to my local machine. N ow could you give the copy command to copy the image to the CAM/CAS /store folder.
It is called upload the image to the devices.
Swami
Faisal Sehbai Mon, 02/15/2010 - 12:54
  • Gold, 750 points or more
Swami,
Use WinSCP (google for it) and you can upload files to the CAM/CAS /store directory using that.
HTH,
Faisal
