BGP
Feb 14th, 2010
Hi experts,
We have the following senario and I need a sloution for it please.
The current senarion is one router installed in HQ for each romote sites and BGP is configured among them.
The needed senarion:
On 3845 router installed in HQ and connected to more than 4 remote sites, each remote site has it is own AS.
How can we configure the HQ router wich connected to more than router with more than AS.
Thanks...
Overall Rating: 5 (1 ratings)
Peter Paluch Sun, 02/14/2010 - 03:34
  • Cisco Employee,
In short - you cannot. A router can run only one BGP instance and therefore belong only to a single AS. Within BGP paradigm, the boundary between autonomous systems is on links, not on routers.
Having each of your routers running BGP in a different autonomous system should not be a problem at all. Do you have a problem configuring your router to run BGP peering with other neighbors in different ASes?
Best regards,
Peter
amarmn1975 Sun, 02/14/2010 - 04:37
Thanks for your reply..
I just want you to know that now we have three routes in HQ connected to three remote sites each router has it is instant . Now we want to bring a big router and plug all the links to it.
Regards..
Ammar Al Hayyani
IP Telephony Specialist
Information Technology
Abu Dhabi Ports Company
Phone +971 2 695 2142   +971 50 6146553
Fax +971 2 695 2111
Email [email protected]
PO Box 54477, Abu Dhabi, UAE
Website www.adpc.ae
Giuseppe Larosa Sun, 02/14/2010 - 05:21
  • Hall of Fame,
    Founding Member
Hello Ammar,
as Peter has noted building 3-4 eBGP sessions is not a problem.
Use a new and different AS number on HQ router.
router bgp 65001
neigh 10.10.10.2 remote-as 65002
neigh 10.10.20.2 remote-as 65003
neigh 10.10.30.2 remote-as 65004
neigh 10.10.40.2 remote-as 65005
some notes :
use private AS numbers in range (64512-65535) it can be helpful for the future.
if you want to build sessions using loopbacks you need to provide:
static routes to tell how to reach the BGP endpoint
you need to use
conf t
ip route 20.20.20.2 255.255.255.255 10.10.10.2
router bgp 65001
neigh 20.20.20.2 remote-as 65002
neigh 20.20.20.2 update-source loop1
neigh 20.202.20.2 ebgp-multihop 2
Hope to help
Giuseppe
Peter Paluch Sun, 02/14/2010 - 08:50
  • Cisco Employee,
Giuseppe,
Thanks a lot for adding to my answer.
In situations where two directly connected routers should be peered in eBGP using their loopbacks, I often like to use the disable-connected-check option instead of ebgp-multihop. The disable-connected-check skips the test whether the peer is on a directly connected network but still sends the TCP packets using the TTL=1.
Best regards,
Peter
Reza Sharifi Sun, 02/14/2010 - 14:19
  • Cisco Designated VIP,
    2017 LAN
paluchpeter wrote:
Giuseppe,
Best regards,
Peter
Hello Peter,
Good seeing you on the forum.
Regarding BGP disable-connected-check, this command has to deployed in addition to ebgp-multihop command not instead.
So, I am wondering, what is the use of disable-connected-check command if you have to use it in conjunction with ebgp-multihop.  You may as well just use "ebgp-multihop 2"and not worry about disable-connected-check command at all.
Reza
This command is required only when the neighbor ebgp-multihopcommand is configured with a TTL value of 1. The address of the single-hop eBGP peer must be reachable. The neighbor update-sourcecommand must be configured to allow the BGP routing process to use the loopback interface for the peering session.
Examples
In the following example, a single-hop eBGP peering session is configured between two BGP peers that are reachable on the same network segment through a local loopback interface on each router:
BGP Peer 1
Router(config)# interface loopback 1
Router(config-if)# ip address 10.0.0.100 255.255.255
Router(config-if)# exit
Router(config)# router bgp 64512
Router(config-router)# neighbor 192.168.0.200 remote-as 65534
Router(config-router)# neighbor 192.168.0.200 ebgp-multihop 1
Router(config-router)# neighbor 192.168.0.200 update-source loopback 2
Router(config-router)# neighbor 192.168.0.200 disable-connected-check
Router(config-router)# end
Peter Paluch Sun, 02/14/2010 - 22:17
  • Cisco Employee,
Hello Reza,
Thank you for your kind words - I am also glad to have found some time to visit the forum again.
Regarding the snippet from the command reference you have posted - I believe it should be understood in the following way: The disable-connected-check is meaningful only if the ebgp-multihop is set to 1. Having the ebgp-multihop set to higher value than 1 also implies the disable-connected-check though it may not be visible in the configuration.
Note that for eBGP peers, the ebgp-multihop 1 is the default value:
R2(config)#router bgp 1
R2(config-router)#nei 1.2.3.4 remote-as 2
R2(config-router)#nei 1.2.3.4 ebgp-multihop 1
R2(config-router)#exit
R2(config)#do show run | sec router bgp
router bgp 1
no synchronization
bgp log-neighbor-changes
neighbor 1.2.3.4 remote-as 2
no auto-summary
R2(config)#
So - yes, the command reference is correct, the disable-connected-check should be used with ebgp-multihop 1, however, that is already the default value with eBGP peers. It does not have any effect with ebgp-multihop set to 2 or more.
Does this make more sense?
Best regards,
Peter
Reza Sharifi Mon, 02/15/2010 - 06:22
    2017 LAN
paluchpeter wrote:
Hello Reza,
router bgp 1
no synchronization
no auto-summary
R2(config)#
Best regards,
Peter
Hello Peter,
Yes, it does make sense.  I think what is confusing about ebgp-multihop command is that usually a default command is not a command you manually have to add.  for example when you create a new BGP session as the one you did here, the command "bgp log-neighbor-changes" and/or "no auto-summary" is already included so you don't need to added them manually.  But in the case ebgp-multihop you have to added it with value on 1 and then it does not show it in the config.  The other interesting part of this command is that if you enter ebgp-multihop without any values, it will assign 255 which is the highest.
T-1(config-router)#neighbor 10.10.10.1 remote-as 100
T-1(config-router)#neighbor 10.10.10.1 ebgp-multihop
T-1(config-router)#do sh run | sec bgp
router bgp 65222
neighbor 10.10.10.1 ebgp-multihop 255
Reza
Peter Paluch Mon, 02/15/2010 - 08:03
  • Cisco Employee,
Hi Reza,
I would personally put it down this way:
    1. There are default commands which are visible in the configuration, and there are default commands which are invisible. This is a matter of the configuration parser in IOS and there is little to be done about it. It is in my opinion one of the confusing things about IOS CLI - it's not consistent.
    2. For eBGP peers, the ebgp-multihop 1 is the default setting.
    3. Specifying only ebgp-multihop without specifying the TTL value causes the TTL 255 to be used. Obviously, we have to distinguish between a default (i.e. used when not explicitely specified) command, which is the ebgp-multihop 1, and a default parameter of an explicitely specified command ebgp-multihop, which is 255.
Best regards,
Peter
milan.kulik Mon, 02/15/2010 - 08:56
  • Red, 2250 points or more
Hi Peter,
I agree, just one comment:
ad 1. default commands which are visible in the configuration:
IMHO, commands which are default in the latest IOS but were not in some previous IOS releases are visible and inserted automatically to keep backward compatibility.
BGP "no auto-summary" is a good example - command default behavior changed to disabled since 12.2(8)T.
BR,
Milan
Peter Paluch Mon, 02/15/2010 - 11:54
  • Cisco Employee,
Hi Milan,
You're absolutely correct. That makes perfect sense. Thanks!
Best regards,
Peter
