Link State Tracking on 6500 Switch
Feb 14th, 2010
which ios version I have to install on 6500 Switch to be able to configure "link state tracking" feature ?
I was looking for this command in "Command Lookup" tools but without any results but I can configure this feature with the previous command on 3750 Switch !!!!!
Giuseppe Larosa Mon, 02/15/2010 - 05:41
Hello Fadi,
may you provide a context?
are you trying to use Flexlinks, or you would like to track an object for example to use reliable static routing?
Hope to help
Giuseppe
ricarrar Tue, 03/16/2010 - 11:34
Hello Fadi!
Link state tracking (as it's implemented on the 3750) is not supported on the 6500.  You should be able to do what you want with EEM though.
Richard
