Qos on cisco 3550
Feb 15th, 2010
Hi all,
I am trying to limit the bandwidth to 10 mbps for one of my customer on 3550 switch.My configuration as follows but its not working.
mls qos
ip access-list extended upload
permit ip any any
class-map match-all INPUT
  match access-group name upload
policy-map POLICY_INPUT
  class INPUT
    police 10240000 1920000 exceed-action drop
interface fastEthernet0/5
service-policy input POLICY_INPUT
1. Queueing strategy is still in  fifo
2. HMG-2ndL3#sh mls qos interface fastEthernet 0/5
Attached policy-map for Ingress: POLICY_INPUT
trust state: not trusted
trust mode: not trusted
COS override: dis
default COS: 0
DSCP Mutation Map: Default DSCP Mutation Map
trust device: none
3. HMG-2ndL3#sh policy-map interface fa0/5     (packets are not hitting)
  service-policy input: POLICY_INPUT
    class-map: INPUT (match-all)
      0 packets, 0 bytes
      30 second offered rate 0 bps, drop rate 0 bps
      match: access-group name DTDCqm_police_inform_feature: CLASS_SHOW
    class-map: class-default (match-any)
      0 packets, 0 bytes
      match: any
        0 packets, 0 bytes
        30 second rate 0 bps
Hariharan k
Kevin Dorrell Mon, 02/15/2010 - 00:58
Could you do a show class-map INPUT please?
Your sh policy-map interface fa0/5 shows the access-group as "DTDC", not "upload" as I would have expected.
Kevin Dorrell
k.hariharan1 Mon, 02/15/2010 - 01:07
below is my orginal configuration in 3550. In my previous post i just manipulated the name of class-map and policiy map.
mls qos
ip access-list extended DTDC
permit ip any any
class-map match-all DTDC-INPUT
  match access-group name DTDC
policy-map POLICY_DTDC
  class DTDC-INPUT
service-policy input POLICY_DTDC
HMG-2ndL3#sh class-map DTDC-INPUT
Class Map match-all DTDC-INPUT (id 1)
   Match access-group name DTDC
Kevin Dorrell Mon, 02/15/2010 - 01:17
OK, that explains the discrepency.
So the next question must be .. (... and I'm sorry it looks like a dumb question ...) ... is Fa0/5 actually up, and is there any traffic actually passing through it?
Kevin Dorrell
k.hariharan1 Mon, 02/15/2010 - 01:21
HMG-2ndL3#sh int fa0/5
FastEthernet0/5 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 0012.7fab.1980 (bia 0012.7fab.1980)
  Description: DTCT - Jeet fiber
  Internet address is 203.196.144.x/30
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 3/255, rxload 6/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:04, output 00:00:02, output hang never
  Last clearing of "show interface" counters 2w2d
Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 2562000 bits/sec, 570 packets/sec
  30 second output rate 1234000 bits/sec, 337 packets/sec
Hariharan k
k.hariharan1 Mon, 02/15/2010 - 02:41
can anyone help me to configure the bandwidth limt in 3550 switch in interface level , like how we will do it in cisco routers
by using rate-limit command.
Hariharan k
francisco_1 Mon, 02/15/2010 - 03:31
On Cat switch for example on the  Interface Configuration Mode on the switch port, you could apply the srr-queue bandwidth limit command. Here’s an example:
Switch(config)# interface FastEthernet 0/1
Switch(config-if)# srr-queue bandwidth limit 90
The 90 sets the outbound bandwidth limit on the port to 90 percent of the port speed. Since this is a 100-Mb port, this should limit the outbound traffic from the port to 10 Mb
Another example is  on a Cisco router when in Interface Mode, you could limit outbound bandwidth to 1 Mb using the following command:
Router(config-if)# rate-limit output 10000000 2000 2000 conform-action continue exceed-action drop
k.hariharan1 Mon, 02/15/2010 - 03:55
first thanks for your reply
rate-limit output is for the download traffic
rate-limit input is for upload traffic in serial interface
i am trying to do the bandwidth limit for my customer upload traffic.
cisco 3550 (input rate)<---------fiber link ---------->(output rate) customer device
also i check in my 3550 fastethernet interface there is no  command like
srr-queue bandwidth
that might be due to my IOS
HMG-2ndL3(config-if)#srr-queue ?
% Unrecognized command
Is there any other alternative way to do this.
Hariharan k
Nicholas Poole Wed, 05/19/2010 - 03:30
you need to apply a policy-map which polices the traffic to the rate that you want and then apply it via the service-policy command on an interface
Related Content
