authenticatin on Novell edirectory
Feb 15th, 2010
Hi All,
We are replacing the Nortel wireless with Cisco solution ( WLC and APs). Authentication on the current solution uses freeradius which uses LDAP to Novell e-directory.
I must implement the Cisco solution and still use Novel e-directory for authetication. I have been in the lab trying to test this and I am not winning.I have setup 802.1x between clients and controller.  The controller sends the credentials to the radius server but the authentication always fails. I have two questions regarding this problem,
1. Is this solution possible, if so what could I be doing wrong?
2. Has anyone implemeted this , if so what is the step by step setup?
Kind Regards,
sslittle Fri, 09/09/2011 - 04:27
Hi Keith,
Did you ever get this working as I am about to start a project with Cisco WLAN controllers in a Novell enviorment and looking to use Free Radius. Any advice will be appreciated.
Trending Topics - Security & Network
