lightweight access-point joined the wireless controller but no radio channels
Feb 15th, 2010
a customer  wireless controller 2106  he use  access-point AIR-LAP1252G-E-K9  the access point the leds indicate
etherner and radio is blinking green and status is green.
please help i am in the customer company now
Leo Laohoo Mon, 02/15/2010 - 13:16
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
You forgot to inform us what is the firmware you are using?
Upgrade your WLC2106 to 6.0.182.0 or later and this will allow the 1250 to operate both radios at standard PoE (15.4w).
I know this will work because I have over 150 1250 operating (in both autonomous and lwapp) drawing only 15.4w.
Please rate my post if appropriate or useful.
John.Gerlach Mon, 02/15/2010 - 09:30
The AP1252 has higher power requirements than some of the Cisco PoE switches provide.  Depending on the switch you are plugging them into you will get enough power to power up the device and connect to a controller but not enough to power up the antennas.  Options that can work include:
1) Removing one of the antennas if you are not gonig to use it (or as a temporary workaround to get some wireless)
2) Using an external power supply
3) Using an external inline power appliance system that supplies enough power (http://www.microsemi.com/powerdsine/ is one example).
4) Depending on the type of switch you are connecting to you may be able to upgrade code to provide a higher amount of power to the port.  For instance, a Catalyst 6500 by default supplies 15.8 watts of power to a port.  But if you upgrade the code to 12.2(33)SXH2? I believe you can get 16.8 watts of power and this is enough to bring up both antennas on the AP.  But even then you don't have enuf power to run the upper N speeds - I think anything above 72 Mbps is unattainable.
Other AP models such as the 1140 have lower power requirements and may work better for you.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
