L2 MPLS VPN between different branches
Feb 15th, 2010
  • Bronze, 100 points or more
Dear Experts ,
I want to have my different offices to use same IP address range (from a centrally managed DHCP server)  . Is this scenario possible with MPLS L2 VPN ?
I know that we can do L2 between two branches by using xconnect  but what if i have multiple branches ?
regards
haris
amit.bhagat Mon, 02/15/2010 - 15:07
You purpose can be solved using VPLS.
You can also create multiple Pseudowires from the HUB to different branches, however, all PWs will use different IP address range- which goes against your requirement.
HTH.
Amit.
shivlu jain Mon, 03/15/2010 - 00:53
  • Silver, 250 points or more
In Cisco, if you want to offer VPLS services then minimum hardware requirement is 7600 with SIP 400 or 600.
regards
shivlu jain
www.mplsvpn.info
