Problems with accessing Cisco Unity 4.2 Build 4.2(1) from a remote computer via a web browser
Answered Question
Feb 15th, 2010
In my "Cisco Unity 4.2 Build 4.2(1)" installation, I can log-in to the cunity1 server (the server with the Cisco Unity 4.2.(1) installed), and on the server, I can open the web-page: http://cunity1/Web/SA/Default.htm, this page opens the page: http://cunity1/Web/SA/FrameASP/StartFrame.asp?CookieCheck=1.
This page I use to administrate the voicemails.
When I try to open this web page on my client computer (Internet Explorer 7.0), I get the following error message:
Missing live session flag.
For some reason, /web/global.asa did not fire.
Check that this file is present.
This problem could also be related to DNS issues.
Cannot continue.
If I use a refresh on this page, I get this:
Microsoft VBScript runtime error '800a01a8'
Object required: '[undefined]'
/Web/Common/include/SaConstInc.asp, line 9
Server.CreateObject(AvSaLocalization.AvSaLocalization.1) failed.
This is most likely an error with a DLL, probably <span style="font-family: Arial;">AvSaLocalizationSvr.dll</span> or perhaps <span style="font-family: Arial;">AvSaLocaleInfoSvr.dll</span>.
Check that these files are present, and registered with <span style="font-family: Arial;">REGSVR32</span>.
Also be sure that the appropriate MsgStoreRes.dll file is present.
Cannot continue.
(From: Global.asa: hr=0x80070005)
error '80004005'
/Web/Common/include/SaLocalizationInc.asp, line 35
What do I need to do, before I can open the web page on my client computer, and administrate the voicemails?
Kind regards,
Carl-Marius
Correct Answer by Brandon Buffin about 7 years 1 week ago
Have you tried registering the DLLs mentioned? Can you ping cunity1? Does it resolve to the correct IP address? Can you access the Unity SA by using the IP address instead of the hostname? See the following link for SA Web troubleshooting steps.
https://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a00801ba0ef.shtml
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Mon, 02/15/2010 - 06:08
Hope this helps.
Brandon
Carl-Marius.Steensen Thu, 02/25/2010 - 01:51
Hi Brandon,
Thank you for the answer and your link, I will try and see if I can make this error go away.
Kind regards,
Carl-Marius
Carl-Marius.Steensen Mon, 04/26/2010 - 05:32
Hi Brandon,
I tried to registering the DLL files and reboot the server, afterwards it worked .
Thank you for your help!
Kind regards,
Carl-Marius
