Maximum E1 Cards supported on 2811
Feb 15th, 2010
Hello All,
Wanted to confirm maximum E1 ports supported on 2811 without any performance degradation.
2811 has 4 HWIC slots, i need 8 E1 ports to be connected to different sites.if i populate all 4 slots with VWIC2-2MFT-G703 which makes 8 E1 ports, Any performance issues??
Thanks in advance.
Giuseppe Larosa Mon, 02/15/2010 - 04:51
Hello Hardik,
C2811 is accredited of 120000 pps
ISR 2811 3,000 1.536 120,000 61.44 No
so from the performance point of view it shouldn't be a problem
see file in attachment
the 4 slots can be used as you would like:
>> 4 slots, each slot can support HWIC, WIC, VIC, or VWIC type modules
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/ps5882/product_data_sheet0900aecd8016fa68_ps5854_Products_Data_Sheet.html
So it should work
depending on WAN provider prices in your region you may want to consider the use of a single NM E3 subrate instead of paying for 8 E1 links
Hope to help
Giuseppe
Paolo Bevilacqua Mon, 02/15/2010 - 08:01
Hi, you should use instead:
NM-8CE1T1-PRIor 2x HWIC-4T1/E1
Also in most cases the regular VWIC is OK, do not need the G703 version.
Related Content
