Warning message
data communication error cucm
Feb 15th, 2010
  • Silver, 250 points or more
I have a single CUCM7.X server running in VM however I getting communication error when I try to log in . The web search I`ve seen are for for a Pub, Sub situation so does not seem to apply to this set up . The database "A Cisco DB" is stopped and can not restart it- any ideas ?
thanks
mazenelhourani Mon, 02/15/2010 - 04:54
Do you have DNS enabled? (You can check by using: show network ethernet0 details)
If it's enabled, try to disable DNS from CLI. I'll get you the commands in a next reply.
Another possible cause of the problem, did you change the IP of the call manager?
iptuser55 Mon, 02/15/2010 - 05:08
Thanks, I will check the DNS. the IP has not been changed - that I know
