NetConfig job failing with RME_CDL1031
Feb 15th, 2010
I have a NetShow job that is failing with this message:
ERROR:RME_CDL1031:Transport  session to device failed Couldnot enter ENABLE mode from USER mode on Device. Couldnot enter ENABLE mode from USER mode on Device.
I have double checked  the credentials in DCR (manually and using the 'check device credentials' option) and its configured properly.
Could you please advice what is wrong?
Amit
Joe Clarke Mon, 02/15/2010 - 17:47
If you are using telnet, the easiest thing to do is get a packet capture of all tcp/23 traffic between the RME server and the device when running the Netshow job.  This will show why RME was unable to enter enable mode.
