CTS Phone alert "Call is being disconnected"
Feb 15th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
I've found a problem in CTS3000 when I end a call in the phone appears "Call is being disconnected", but the alert do not change until I press the service button, and sometimes I’ll need to do a phone reset to see again the service in my phone, In another room with CTS1000 I don’t have any problem.
Pedro Silva
Overall Rating: 4.5 (2 ratings)
Marwan ALshawi Tue, 02/16/2010 - 02:13
are you running XML phone service ?
if yes may be the problem from the XML service
what is your CTS and cucm versions
i would recommend you to use Midlet as the service for the IP phone if its not in use
but it need the follwoing:
CUCM 7.0.2 or above, SIP load should be  8.4.3 or above, CTS 1.5
campizi28 Tue, 02/16/2010 - 08:20
Cisco 7970 -> SIP70.8-5-2SR1S
CTS3000 -> CTS 1.6.0(3954)
CTSManager -> 1.6.2(64)
CTMS -> 1.6.1
In attach are the configuration of the services.
Marwan ALshawi Tue, 02/16/2010 - 14:55
the service you're using is XML the one i mentioned above is java based and will be the supported one ni the new releases of TP
any way you have the services http link misconfigured
just change the services link to the bellow:
then save and reset the phone
good luck
if helpful Rate
gogasca Wed, 02/24/2010 - 02:01
I would upgrade my phone to 8.5.3
Can we reproduce the problem?
Other room same CTS/IP Phone load version?
If so we can check http logs to see whats happening
Any reason why you guys not using midlets?
campizi28 Fri, 02/26/2010 - 03:12
The other room is the same CTS/PHone version, and i didn't found any http issue in the logs
gogasca Sat, 02/27/2010 - 03:42
Check URLs are correct services, authentication and idle as well as IDLE timer, compare both phone if you see the same please open a TAC case with us
