How to Setup a Second Auto Attendant for Inbound calls in CCA
Answered Question
Feb 15th, 2010
Is there a simple way to set up a second AA in CCA?
My customer has a second division that has a separate published number.  They want a separate AA for the callers to access when the number is called.
They have a main inbound number that hits the AA, but want another AA for calls to the the other number.
Thank you.
Correct Answer by aapexisinc about 7 years 2 weeks ago
I've done this exact setup on a UC520.  It's relatively easy to do using CUE's web interface, not CCA.
Overall Rating: 5 (1 ratings)
Correct Answer
aapexisinc Mon, 02/15/2010 - 08:25
