Rip redistribution problem
Feb 15th, 2010
Hi There,
Can  anyone please help me? When i redistribute connected into ospf and specify a route map and then i redistribute routes using RIP, what happens is the routes filtered earlier using route map don't get advertised into OSPF even though they are in RIP database.
Thanks in advance
Shahzad.
Lei Tian Mon, 02/15/2010 - 08:26
  • Cisco Employee,
Hi Shahzad,
When you redistribute RIP into OSPF, there will have 2 things happen:
1, the RIP routes in RIB (routing information base) will be redistributed into OSPF.
2, the connected interfaces which participate in RIP process will be redistributed into OSPF.
When you redistribute the connected routes into OSPF, it actually breaks the 2nd step. So only routes match in the route-map will be redistributed into OSPF.
HTH,
Lei Tian
mshahzadqadir Mon, 02/15/2010 - 08:30
Thanks Lei, what I am trying to achieve is -
I want to redistribute one of the connected interfaces using red connected with a specific metric and other interface using rip. this is requirement of a lab I am doing at the moment, any cluses how I can do that?
Shahzad.
Lei Tian Mon, 02/15/2010 - 08:39
  • Cisco Employee,
Hi Shahzad,
For example you have 3 interfaces, fa0/0, fa0/1 and fa0/2. fa0/1 and fa0/2 are participating in RIP process. You want redistribute fa0/0 into OSPF with a particular metric.
You can have 2 permit statement on your route-map; 1st statement match interface fa0/0 and set the metric, 2nd statement match interfaces fa0/1 and fa0/2 with your default metric.
HTH,
Lei Tian
mshahzadqadir Mon, 02/15/2010 - 08:42
Thanks but in this case both routes will appear as redistribute connected routes. they will not appear as rip routes.
Lei Tian Mon, 02/15/2010 - 08:52
  • Cisco Employee,
Hi Shahzad,
The directly connected routes will appear as "C" regardless. They will not show as RIP routes in the local RIB. Not sure if that is what you were asking.
HTH,
Lei Tian
mshahzadqadir Mon, 02/15/2010 - 09:29
Hi Lei,
Actually what I was saying is when I do "show ip ospf database external" the routes redistributed into ospf will look as they were redistributed from connected. NOT as redistributed from RIP.
Shahzad
Shahzad Qadir
Level 2 On-site Engineer
Dimension Data United Kingdom
Tel: +44 208 7606 476
Mob: +44 78 2598 1003
Fax: +44 12 5277 9010
[email protected]
Dimension Data House, 2 Waterfront Business Park, Fleet Road, Fleet, Hampshire, GU51 3QT, United Kingdom
For further information about Dimension Data, please go to http://www.dimensiondata.com/
P Before printing this email please think about the environment
Lei Tian Mon, 02/15/2010 - 09:40
  • Cisco Employee,
Hi Shahzad,
Can you post your show output and tell me exactly what difference did you see on the output?
Lei Tian
mshahzadqadir Tue, 02/16/2010 - 02:49
Lei,
Please have a look at following output:
R1 (RUNNING OSPF ONLY)
R1#s
FastEthernet0/0 unassigned YES unset administratively down down
Serial0/0 10.10.10.1 YES manual up up
FastEthernet0/1 unassigned YES unset administratively down down
Serial0/1 unassigned YES unset administratively down down
R1#sh run | b router ospf
router ospf 1
log-adjacency-changes
network 10.10.10.1 0.0.0.0 area 0
R2 (RUNNING OSPF AND RIP)
R2#s
FastEthernet0/0 10.10.20.1 YES manual up up
Serial0/0 10.10.10.2 YES manual up up
Serial0/1 10.10.10.5 YES manual up up
Loopback1 unassigned YES unset up up
R2#sh run | b router ospf
router ospf 1
redistribute connected subnets tag 10 route-map con-2-ospf
redistribute rip subnets tag 20
network 10.10.10.2 0.0.0.0 area 0
router rip
version 2
passive-interface default
no passive-interface Serial0/1
network 10.0.0.0
no auto-summary
route-map con-2-ospf permit 10
match interface FastEthernet0/0
set metric-type type-1
route-map con-2-ospf permit 20
match interface Serial0/1
set metric-type type-2
R2#sh ip ospf data
OSPF Router with ID (10.10.10.5) (Process ID 1)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
10.10.10.1 10.10.10.1 230 0x80000002 0x008087 2
10.10.10.5 10.10.10.5 15 0x80000002 0x002CD4 2
Type-5 AS External Link States
Link ID ADV Router Age Seq# Checksum Tag
10.10.10.4 10.10.10.5 15 0x80000001 0x00E96A 10
10.10.20.0 10.10.10.5 15 0x80000001 0x003299 10
R2#sh ip ospf data
10.10.10.4 10.10.10.5 48 0x80000001 0x00E96A 10
10.10.20.0 10.10.10.5 48 0x80000001 0x003299 10
If you look at external database, the routes are appearing with tag=10 that is for connected. So no RIP routes are getting redistributed. Just connected routes are there.
I was wondering if there is any way I can actually redistribute rip routes (with tag=20).
I hope output make some sense.
Thanks for looking.
Shahzad.
Shahzad Qadir
[email protected]
Giuseppe Larosa Tue, 02/16/2010 - 03:15
  • Hall of Fame,
    Founding Member
Hello Shahzad,
have you got a RIP neighbor on interface ser0/1 of this router?
post
sh ip route rip
if there is no RIP neighbor in the only active interface, no RIP routes can exist on the local node.
And the redistribute connected in OSPF arrives first.
Hope to help
Giuseppe
mshahzadqadir Tue, 02/16/2010 - 04:05
Hi Giuseppe,
Yes, RIP neighbor is active there and receiving other routes and I can see these routes in "show ip rip database" output.
Are you saying if ospf is learning same routes from red connected & red rip then router will prefer connected routes and ignore rip redistributed routes?
Shahzad.
Shahzad Qadir
[email protected]
Giuseppe Larosa Tue, 02/16/2010 - 04:48
  • Hall of Fame,
    Founding Member
Hello Shahzad,
if I've understood you correctly there are RIP routes and and a RIP neighbor but no RIP route is redistributed into OSPF.
I think that the issue is the following:
an LSA external route cannot be advertised if its next-hop = forwarding address in OSPF terminology is not known via an internal route either intra or inter area.
All RIP routes have an IP next-hop of the router on the other side of serial 0/1.
section 16.4 RFc 2328
http://www.rfc-editor.org/rfc/rfc2328.txt
If the forwarding address is non-zero, look up the
            forwarding address in the routing table.[24] The matching
            routing table entry must specify an intra-area or inter-area
            path; if no such path exists, do nothing with the LSA and
            consider the next in the list.
So I would suggest the following:
under router ospf
add a network ... area command for ser0/1 IP subnet
passive-interface ser0/1
the redistribute connected provides an external route to RIP routes next-hop,
so they cannot be referenced in another external LSA as specified in RFC 2328.
This should make the RIP routes to appear as external routes in OSPF LS DB.
Hope to help
Giuseppe
mshahzadqadir Tue, 02/16/2010 - 05:14
Hi Giuseppe,
Sorry for the confusion, what I want is:
1. I have 2 interfaces on R2, one is part of RIP process and other is NOT.
2. I want to advertise RIP interface (also connected to R2) to be redistributed into OSPF as external RIP route
3. and I want other connected interface to be redistributed to OSPF as external Connected route.
Does it makes sense? I have no problem with RIP redistribution. Just I want to know why OSPF is preferring connected red routes over RIP red routes.
Hi Lei - my problem is not with route tags, all I want is external RIP routes not external connected route.
Shahzad.
Shahzad Qadir
[email protected]
Giuseppe Larosa Tue, 02/16/2010 - 05:27
  • Hall of Fame,
    Founding Member
Hello Shahzad,
for getting this you should:
deny the desired subnets from being redistributed into OSPF by using a route-map
access-list 11 permit 10.10.10.0
route-map selected_conn deny 10
match ip address 11
route-map selected_conn permit 20
router ospf
red connected subnets route-map selected_conn tag 10
red rip subnets tag 20
edit:
red connected arrives first, or to say more precisely is preferred over importing RIP routes
Hope to help
Giuseppe
mshahzadqadir Tue, 02/16/2010 - 05:54
Hi Giuseppe,
If I deny a route, it don't get advertised to OSPF. NOT from connected and not from RIP.
Shahzad.
Shahzad Qadir
[email protected]
Lei Tian Tue, 02/16/2010 - 06:06
  • Cisco Employee,
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Hi Shahzad,
Sorry if I miss understood your requirement.
Once the routes get redistributed into OSPF, it will appear as external type routes; there is no difference get redistribute from RIP or from connected. You can configure different metric-type or tag to differentiate those routes.
As I already mentioned when you have redistribute connected, it will overwrite the default behavior of redistributing from routing protocol 1 to routing protocol 2.
HTH,
Lei Tian
Lei Tian Tue, 02/16/2010 - 04:40
  • Cisco Employee,
Hi Shahzad,
If you want redistribute RIP into OSPF with metric type 2 and tag the routes with 20; redistribute interface s0/1 into OSPF with metri tryp 2 and tag it with 10; you can configure your route-map as follow
set tag 20
set tag 10
Within your OSPF, change it to
redistribute connected subnets route-map con-2-ospf
That should satisfy all your requirements.
HTH,
Lei Tian
