snmp traps
Feb 15th, 2010
Hello Experts,
I have enabled all snmp traps on 6500 switch,i want to know the description of each trap and severty level for each trap,where can i find it???
can anybody route me to the proper document.
snmp-server system-shutdown
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps chassis
snmp-server enable traps module
snmp-server enable traps transceiver all
snmp-server enable traps ds1
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps casa
snmp-server enable traps tty
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps atm subif
snmp-server enable traps bgp
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps config-copy
snmp-server enable traps event-manager
snmp-server enable traps frame-relay
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps l2tc threshold
snmp-server enable traps MAC-Notification change move threshold
snmp-server enable traps msdp
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps rf
snmp-server enable traps rtr
snmp-server enable traps slb real virtual csrp
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps mvpn
snmp-server enable traps isakmp policy add
snmp-server enable traps isakmp policy delete
snmp-server enable traps isakmp tunnel start
snmp-server enable traps isakmp tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps mpls traffic-eng
snmp-server enable traps mpls fast-reroute protected
snmp-server enable traps mpls ldp
snmp-server enable traps pw vc
snmp-server enable traps memory bufferpeak
snmp-server enable traps flex-links status
snmp-server enable traps sonet
snmp-server enable traps dial
snmp-server enable traps fru-ctrl ps-output-change status
snmp-server enable traps entity
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps power-ethernet group 1-48
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps csg agent quota-server database
snmp-server enable traps srp
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps c6kxbar intbus-crcexcd intbus-crcrcvrd swbus
snmp-server enable traps dot1x no-guest-vlan no-auth-fail-vlan
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps port-security
snmp-server enable traps vswitch vsl
snmp-server enable traps alarms
snmp-server enable traps vlan-mac-limit
snmp-server enable traps mpls vpn
snmp-server enable traps voice poor-qov
Reza Sharifi Mon, 02/15/2010 - 12:29
  • Cisco Designated VIP,
    2017 LAN
Are you looking for this command?
The severty  is after alarms
Switch(config)#snmp-server enable traps ala
Switch(config)#snmp-server enable traps alarms ?
  <1-4>          Max Severity of the Alarm Notifications
  critical       Service affecting Condition       (severity=1)
  informational  Informational notifications       (severity=4)
  major          Immediate action needed           (severity=2)
  minor          Minor warning conditions          (severity=3)
Reza
thomasandy32 Mon, 02/15/2010 - 20:44
Hello Sharifi,
I m looking for the severity level of each traps that i have enabled. For Example: suppose if switch module goes faulty then snmp-server enable traps module trap will be triggered , so this trap will be in which severity ???
Feb 16 16:37:02.499: %C6KPWR-SP-2-PSFAIL: power supply 2 output failed.
Feb 16 16:37:02.503: %SNMP-5-CHASSISALARM: Chassis Alarm Trap: tmpAlarm(OFF), minorAlarm(ON), and/or majorAlarm(OFF)
I'm receiving snmp traps in syslogs how i can see only snmp traps apart from the syslogs.what is the command to chk snmp traps on the 6500 switch??.
thomasandy32 Wed, 02/17/2010 - 11:56
Hello friends,
Can anybody helpme for the above query.
thomasandy32 Mon, 02/22/2010 - 18:13
Hello Dears
Nobody from cisco experts can answer my above question????  Answer will be highly appreciable.
milan.kulik Tue, 02/23/2010 - 04:30
  • Red, 2250 points or more
my understanding is:
Each of the commands
"snmp-server enable traps xxxx"
enables one family (Cisco calls it type) of traps being sent.
snmp-server enable traps stp - enables STP traps, e.g., all severities.
I'm not sure if it's possible to configure severity of particular traps with IOS, though.
I remember this was possible in CatOS in the past.
Traps are sent to SNMP port (UDP 162 if I remember correctly). You need a SNMP trap receiver program (like HP OV NNM, e.g.) to handle the traps received then.
"snmp-server enable traps syslog" makes the switch to sent a copy of each trap to your Syslog, too.
HTH,
Milan
Pierre Nelson Fri, 01/13/2012 - 12:48
I have to correct what snmp-server enable traps syslog actually does.  It sends what ever is sent to syslog as an snmp OID to what you have recieving your traps.  I wouldn't turn this on if you have a huge network or you will be bombarded with a tone of syslog messages.
