BGP MED preference (0 vs NULL)
Answered Question
Feb 15th, 2010
Does anyone know what's cisco's preference when dealing with a path that has a MED set to 0 and a path that does not have a MED set (assuming everything else is default)?
Thank you,
Tom
Correct Answer by Peter Paluch about 7 years 1 month ago
Tomek,
As far as I know, this depends on the setting of the BGP process.
By default, if the MED attribute is missing, the IOS assigns the value of 0 to the route. You can change this behavior using the command bgp bestpath med missing-as-worst in which case the missing MED attribute will be internally assigned the value of 4294967294.
You may want to read the following link to the command reference:
http://www.cisco.com/en/US/partner/docs/ios/iproute/command/reference/irp_bgp1.html#wp1012195
Also, this document may be very interesting to read:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml
Best regards,
Peter
Overall Rating: 5 (2 ratings)
Correct Answer
Peter Paluch Mon, 02/15/2010 - 14:00
  • Cisco Employee,
Tomek,
Best regards,
Peter
Peter Paluch Mon, 02/15/2010 - 15:06
  • Cisco Employee,
Tom,
Thank you for the link!
Best regards,
Peter
Related Content
