Perform CAD autologin (CAD Services)
Feb 15th, 2010
I'm trying to know if there is any possibility to perform an autologin into CAD. I know that I perform an autologin when I use CTI OS Toolkit, if I modify several keys into the windows registry.
Could anybody help me?
david.macias Tue, 02/16/2010 - 06:31
I am going to lean towards no, this is not possible.  All you can do with CAD is basic, rudimentary customization, e.g. remove buttons, add panels, etc.  You could write a 3rd party application that is looking for the CAD login screen and fills it in for you or you could just use CTIOS.
david
bsugamele1 Thu, 02/18/2010 - 12:18
I have set up a one button login for CAD, where you hit the services button on your phone, choose the "One button login" service and it has the agent id and password prefilled and logs the agent in. That is about as close as you are going to get to an auto login.
Brett
