CCNA / CCNP training equipment ?
Answered Question
Feb 15th, 2010
Lookig to buy more equipment for CCNA and CCNP labs. Any preferences on router or switch models and/or the use of 10mb, 100mb, 1000mb, or serial connections?
Correct Answer by Ganesh Hariharan about 6 years 11 months ago
If you have good budget then for training purpose for CCNA and CCNP you can go for 3 switches with model 2960G or 3560G and in routers series you can have 2 routers in the model 1800 and 2800 series with ip advance feature set ios.
With the above said modle you will have experience in switching and routing also and even qos configuuartion and all stuff.
Hope to help
If helpful do rate the post
Ganesh.H
Overall Rating: 0 (1 ratings)
Correct Answer
Ganesh Hariharan Wed, 02/17/2010 - 08:57
Hope to help
Ganesh.H
