catalyst 2950 and 3750 console not responding after successful boot
Feb 15th, 2010
i just removed two switches from my ccie R&S lab but now i has a very strange problem switches is working fine but i can not access from console after boot .
Leo Laohoo Mon, 02/15/2010 - 20:04
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Someone must've adjusted the baud settings.
khalid_lali Tue, 02/16/2010 - 09:34
Baud rate is 9600 its ok even i can see the console logs but cant work on it.
Kevin Dorrell Tue, 02/16/2010 - 20:11
  • Green, 3000 points or more
Do you have any other devices you could use to check your terminal emulator is working?  I had an issue with hyperterminal once, that it would not transmit following a reboot of the device it was managing.  But in my case, re-booting the PC (with a proper power cycle) cleared the problem, so it couzld have been something to do with flow control.
Kevin Dorrell
Luxembourg
Hassan Khawaja Thu, 06/19/2014 - 04:48
Hi Khalid,
       I am having the same problem with 2960 Catalyst Switch. Switch boots and the booting process shows up on console, but after the boot-up, console Hangs. Did you find the solution for your problem? How did you solve it ?
Hassan
