Sticky sessions and Admin context
Muhammad Khan
Please could someone confirm if we can achieve session persistence when configuring load balancing in Admin context i.e. a flat configuration.
I read in the document White_Paper_Cisco_Application_Control_Engine_A_Technical_Overview_of_Virtual_Partitioning.pdf (ACE module) that it is not possible as no resources are allocated for sticky sessions in default class, but I see the following on 4710 appliance
sh resource allocation
Parameter                 Min      Max         Class
sticky                    0.00%    100.00%    default
Any ideas if it is possible at all in Admin Context?
Rgds,
Mo
dario.didio
Level 4
Level 4
yes this is possible.
For stickyness to work, you need to allocate sticky resources for that context.
Create a resource-class, allocate the resources you need and assign that resource class to the Admin context.
HTH,
Dario
